Problems with a lot of solutions... what to start first.
Old Nov 29, 2010 | 09:15 PM
Ugly1's Avatar
Ugly1
Water?
What is the water test supposed to do?
Old Nov 29, 2010 | 09:17 PM
usmcman18's Avatar
usmcman18
I guess its supposed to make the plugs spark more??? I read it on one of the threads. Either way I didnt find anything.
Old Nov 29, 2010 | 09:29 PM
smcandrew08's Avatar
smcandrew08
Take your diff covers off and see if you find any bits of metal in the front or rear end. I had ticking to and I ended up finding metal shards from my rear end in the diff case.
Old Nov 29, 2010 | 10:22 PM
Get your PCV valve from the dealership. The aftermarket fellers aren't worth squat.
I don't think there are any gaskets on the stock exhaust manifolds....
Old Nov 29, 2010 | 10:31 PM
usmcman18's Avatar
usmcman18
There are ones on this engine... I'll take a picture tomorrow of my engine and manifolds. There is a gasket but it looks funny. Maybe another bad job from the previous owner.
Old Nov 29, 2010 | 10:37 PM
Yeah, the 'not so bright' previous owner syndrome.... been there, done that....... If there are indeed gaskets there, its a good bet the PO has been in there..... you may be able to fix it simply by putting in some new gaskets then.
Old Nov 30, 2010 | 09:55 PM
usmcman18's Avatar
usmcman18
I started it up this morning and drove it instantly and it didnt make the tick, but 5 min later when It warmed up it started ticking. I hear the gaskets on the exhaust manifolds can warp and go bad after time and then resulting in a cracked manifold. I'm replacing the gasket tomorrow or thursday, should I replace the gasket at the connection of the manifold/exhaust also? Thanks dudes
Old Nov 30, 2010 | 11:35 PM
Only if you have to.... Those bolts can be a real bare to get out, without breaking them. (or, if you have a hot wrench, warm them up a bit...... and they will buzz right off.) You will probably have to, unfortunately, as changing the gaskets without cleaning the surfaces, probably won't help.
Old Dec 2, 2010 | 11:50 AM
usmcman18's Avatar
usmcman18
Just got done replacing the driver side gasket (i actually double up the gaskets using the old one since it looked ok). Took it for a short drive and no change, still the awful tick tick tick Im going to work on the passenger side this weekend. Do you think I should scrap the gaskets all together?
Old Dec 2, 2010 | 11:52 AM
Need to look at both mating surfaces, and decide from there. If the gaskets that are currently there are leaking... simply adding another one may not solve the issue.
