Are all styles of back windows w/sliding glass interchangable?
In the two picks you showed one is glue in and the other has the rubber seal, they should fit, just different ways to attach it to the truck. Be careful if you go with the rubber seal as they like to leak. If you don’t need the window with the rubber seal, I am interested in it.
We busted the rear glass in a 2000 (glue in). I have a '96 (rubber seal) donor here.
If we get the back glass out of the 2000 (which I understand will suck per other threads here), I just want to super-extra-confirm the rubber seal version should fit? Posts above suggest they interchange, I'm just trying to be absolutely certain.
I find it unlikely (but not impossible) Dodge changed the sheetmetal around the window in '98??
