how to gut my cat
Old Nov 30, 2010 | 05:34 PM
Ram_King's Avatar
Ram_King
Default how to gut my cat
whats the best way?
Old Nov 30, 2010 | 05:43 PM
First, make sure it is dead. Then, get yourself a sharp knife.... oh, what? Not THAT cat?? Oh. Well then......
Take out the pre-cat O2 sensor, disconnect the pipe at the rear of the cat. Get a reasonable long, sharp stick. (preferably something metal.) Use sharp stick to break up substrate in cat. Pick out what you can. When you have it reduced to small chunks, and have removed what you can, start the engine, and rap on it a couple times to blow the rest of the crap out. Reconnect pipe, put O2 sensor back in.
Old Nov 30, 2010 | 05:47 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If you can weld, cut it in half. If not, cut the pipe on the rear side and take a long bar or pipe and beat the crap out of the guts. Remove the precat o2 so you don't damage it. Start it and let all the crap blow out.
Old Nov 30, 2010 | 06:04 PM
Depending on the year of your truck, it may, or may not.... set a code for catalyst efficiency. If your truck is 95 or older, not a concern, as there is only one sensor. 96 and newer have two. If you end up with the code, there is a fix for that too.
wideglide01's Avatar
wideglide01
After you gut the cat,will you have to change anything else or will the 02 sensors still read like they should,been thing about gutting mine as well. Thanks,steve
Old Nov 30, 2010 | 06:05 PM
Originally Posted by zman17
Guess I should hit the refresh button more often, huh Heyyou anyway, the post cat o2 is the one you have to deal with, and here is how to do just that https://dodgeforum.com/forum/2nd-gen...converter.html
The clocks LIE. The board seems to pick a random amount of time to be off on an hourly basis..... I think that has a fair bit to do with the posting silliness as well.
Old Nov 30, 2010 | 06:08 PM
zman17's Avatar
zman17
Old Nov 30, 2010 | 06:09 PM
I'll never tell.
Old Nov 30, 2010 | 06:12 PM
zman17's Avatar
zman17
LOL, it did it again. I thought the last time was just my slow typing.
Old Nov 30, 2010 | 07:16 PM
Pacmanloads's Avatar
Pacmanloads
http://www.dontevenreply.com/view.php?post=95
