Transmission Input from everyone...
Old Dec 3, 2010 | 01:41 AM
J415's Avatar
J415
Originally Posted by UnregisteredUser
That's a great place to install the remote filter, in fact. And the remote filter will provide an anti-drainback valve that does the same job as the factory check valve that's failure prone. It's win:win.
Funny you should mention installing the remote filter there, because that's how I have my rig set up.
Old Dec 3, 2010 | 02:09 AM
Slomojo's Avatar
Slomojo
drop the pan, drain the fluid, change the fluid, filter and gasket. If you got a welder or know someone who does then drill a hole in the lowest part of the pan, weld a good solid nut into the inside of the pan, get a corresponding bolt, washer, and a piece of old radiator hose to make a gasket out of. Cut the hose so that you got a little square that you can drill a hole through for the bolt. Insert washer on bolt and bolt with washer through rubber gasket and use that as your plug. What you will have is a brand spanking new drainplug in your tranny pan. It will make the whole tranny service thing a lot more enjoyable the next time around.
+1 on having the system flushed at a quick lube joint. Just drop the pan, change the fluid filter and pan gasket and be on your way.
Old Dec 3, 2010 | 02:39 AM
kuziwr's Avatar
kuziwr
You guys are awesome! About this remote filter thing and check valve thing. How do i go about replacing that? What does it look like? Any pics.
Old Dec 7, 2010 | 04:51 PM
aarons ram's Avatar
aarons ram
yes pics of what you guys are talking about would be immensely helpful, plus do you guys have any suggestions on what brand/type of fluid to use? I have the manuel but im to lazy.. thanks
Old Dec 7, 2010 | 06:00 PM
nmanchester's Avatar
nmanchester
While were on this topic on interested in the remote filter but was wandering about synthetic fluid and what u guys thought.
Old Dec 7, 2010 | 06:02 PM
my understanding is that atf +4 fluid is synthetic by default........
Old Dec 7, 2010 | 06:18 PM
95RAM360's Avatar
95RAM360
yes all atf4 is synthetic, and DONT use any fluid aside from atf4....from dropping only pan, look to add 5-6 quarts of fluid (@$5.99 a quart...well for the castrol kind i like to get)
and add a drain plug....i brought my pan to the local machine shop, and they put one in for $10 bucks.....not a bad deal at all.....
The check valve is on the passenger side in the motor, at the front where it enter the radiator about mid way up......dont have a pic but thats the best i can describe it....
