Where are you guys getting gears from?
Old Dec 4, 2010 | 05:52 PM
slider15004x4's Avatar
slider15004x4
No, I'm saying that because of the 545rfe I wouldn't consider anything less than 4.56s. But I'd go 4.10s in a 2nd Gen unless the tire size is over 35", then I'd go 4.56s.
So which gears would you go with if you had 35's? 4:10's?
Old Dec 4, 2010 | 06:53 PM
HammerZ71's Avatar
HammerZ71
I'd go 4.10s if I were doing more highway then in town driving. If you mainly drive around town, tow or haul a lot of weight often, then I'd go 4.56s.
You'll tach a bit high over about 60 mph and cost yourself a little bit of fuel economy with 4.56s due to the fact the transmission doesn't have the extra OD that the 545rfe has.
If you've got 3.92s and are not happy, by all means, go 4.56s because 4.10s won't give you enough difference to justify the cost.
It's a tough call, when I had my '98 I had stock 3.92s with 35s and thought they were fine. When I got the Hemi with it's 545rfe and went to 35s, I went down to taching around 1600 at 70 mph on the interstate, found the tranny shifting constantly "searching" for the right gear and actually lagged pretty bad when getting on the gas to pass someone.
4.56s brought me up to around 2000 rpm at 70 mph which is right around where the Hemi "sweet spot" starts to kick in. So the tranny tends to stay locked in one gear and when I touch the gas to pass, the truck snaps forward.
IMO with your transmission not having that extra OD gear in it, you should be taching about where I am with 4.10s...
Old Dec 4, 2010 | 07:09 PM
slider15004x4
I do a little bit of both types of driving, highway and around town. I won't be towing anything bigger than a popup camper.
Old Dec 4, 2010 | 07:32 PM
Silver_Dodge's Avatar
Silver_Dodge
I had 4.10's when I first went to 35's, and it was aweful. At highway speeds the truck was so underpowered, the slightest hill or even a head wind would kick me out of overdrive. 4.56 is the perfect gear for all around use, highway and city. 4.88 if you do less highway.
Old Dec 4, 2010 | 09:08 PM
TheBigRedOne's Avatar
TheBigRedOne
For a full install what will I need? Gears, Locker, and install kits correct? I was told something by one of the guys in the shop about an open carrier?
Old Dec 4, 2010 | 09:10 PM
HammerZ71's Avatar
HammerZ71
What were you taching at highway speeds, Silver? I was taching about 1950 at 60 mph when I had my '98 RCSB 4x4 5.9 with the stock 3.92s and found the power to be more than adequate.
I kinda felt if I was much over 2000 rpm I'd start to lose too much fuel economy. I towed a bass boat all over Georgia, Alabama, SC and north Florida most weekends and I really didn't wanna kill gas mileage. Having the 5.9 was bad enough, LOL...
Old Dec 4, 2010 | 10:06 PM
Pacmanloads's Avatar
Pacmanloads
Yukon Gear through a local shop . Had everything I needed ...although I don't believe they make a Yukon Locker for the 9.25
Old Dec 4, 2010 | 11:07 PM
Silver_Dodge
I don't recall now, but it was aweful. The 4.10's just didn't have any advantage left in them once I got into OD, and the truck couldn't push the 35" mud tires anymore. As soon as I got the 4.56's, that went away completely, and now I have power to spare.
Old Dec 4, 2010 | 11:38 PM
99dodge318's Avatar
99dodge318
4.56's it is thanx silver_dodge!
Old Dec 5, 2010 | 12:00 AM
Silver_Dodge
You will be very happy with them.
