Code P0720
Old Dec 4, 2010 | 10:03 AM
gary30mazak's Avatar
gary30mazak
Default Code P0720
I have a 1998 Doge Ram 2500 4x4 With the 5.9 360. I was driving this morning and all of a sudden it started to really shimmy and almost stalled completely. I pulled over and thew it in park and reved the engine a few times and it purred like a kitten. I then turned it off and restarted it and it threw a CEL. I then drove it about 12 miles home and it ran great. When I got home I got my superchips tuner out and it said the code was a P0720 output speed sensor circuit. I did a search on here on it but I'm a little confused. It seems that I might have 3 output speed sensors but which one would make it run rough like that for only a few seconds? Secondly I think I know where the one on the back differential is but where are the other two? Any ideas? Thanks guys!
BTW the speedo wasn't acting up or anything the motor just ran real rough.
It shows no codes except that one time. i cant't locate the problem at all. Last summer the speedo did act act up andd would go to 2000 at a stop light and just return to normal but thats it. this time it reallly acted up. I almost lost all power and it almost died. It's oviously not an sct tuner proplem and I need to know whot to change myself insdead of having a stearlship soak me!
Old Dec 4, 2010 | 10:06 AM
95RAM360's Avatar
95RAM360
i know theres one towards the front of the motor near the alternator on the 98's, just not sure of exact location....you can eliminate the sensor on the tailhousing of tranny, if it were that one, you'd have no speedo.
Old Dec 4, 2010 | 11:02 AM
You should only have one that matters on a 98, and that one is back on the rear differential. Right up on top. Check the connector, and make sure it is clean, and tight.
Old Dec 4, 2010 | 11:31 AM
zman17's Avatar
zman17
Retired Moderator - RIP
huh?....
Old Dec 4, 2010 | 01:09 PM
gary30mazak
Bumb I'm stumped!
Old Dec 4, 2010 | 01:32 PM
zman17's Avatar
zman17
The sensor is located on the driver side of the tranny right in front/above the tranny mount and skid plate. You also see the two vac lines for the cad right there.
Old Dec 4, 2010 | 02:02 PM
OhioChuck's Avatar
OhioChuck
As zman17 said, it's on the driver side of the transmission near the back. My truck had the same code last summer and I replaced that sensor - new one was under $20 at NAPA. Make sure you have the new one handy before removing the old one because it starts barfing out tranny fluid as soon as you remove it. Very easy to change and gets rid of your P0720 code.
Chuck
Old Dec 4, 2010 | 02:29 PM
gary30mazak
All I see is the one on the rear differental if anyone knows anything else please chime in! I can't find another one and i do have the 1998 dodge rame service manual book but it doesn't cover this or at least I cant find it! Anybody got pics?
Old Dec 4, 2010 | 02:54 PM
gary30mazak
Where is it located? i have a dodge munual and it is not located anywhere? I 'm not a mechihc and would like diy section on this. not to bitch but i'm not very engine or very else inclined. I would like to learn though.
Old Dec 4, 2010 | 02:56 PM
zman17's Avatar
zman17
Didn't two different people tell you where it is?
