how to remove spindle from control arm
Old Dec 5, 2010 | 02:07 PM
dipsherry's Avatar
dipsherry
Originally Posted by zman17
Before you kill yourself with a flying coil spring, do you have a Haynes manual? If so read it, if not go get one.
yeah i do have a haynes and a chiltons... also i have a spring compressor on my coil. thanks for caring about my safety though ;-). i did get one side done with the pickle fork and a lot of motivation from my good friend buddy light and a BFH. to cold to get the other side done hopefully weather gets above 20 degrees this week
Old Dec 5, 2010 | 02:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
So you are doing it like the Haynes says to? I believe a pitman arm puller will work on the lower BJ, which btw, is the only one you have to break loose.
Old Dec 5, 2010 | 07:12 PM
dipsherry's Avatar
dipsherry
doing it like it says i did a little research and most people say the upper is easier to undo so i did it...i did tear the boot on the tie rod end so i just went ahead and replaced it while i was down there...here is a few pics u can prolly judge for yourself which is the lifted side lets see.
Size:  50.6 KBName:  2010-12-05151028.jpg
Size:  38.3 KBName:  2010-12-05152448.jpg
Size:  133.0 KBName:  2010-12-05152512.jpg
