Trouble trifecta
Old Jan 12, 2011 | 10:37 AM
bseeton1's Avatar
bseeton1
tcc dancing i believe...like i said when i manually lock it in it stops. Any ideas? theyre is a spot for a trans relay in pdc box but no relay is mounted there instead the lead for the override switch has got a male spade terminal diving into one of the terminal points. its been this way since i got it but everything transmission wise was working fine. i reseated this termination and i think the tps/iac swap has helped some but its still oscillating from time to time....not as much thought
Old Jan 12, 2011 | 10:41 AM
Have you replace the TCC solenoid yet? They are not an uncommon failure point......
Old Feb 15, 2011 | 02:33 AM
bseeton1's Avatar
bseeton1
replaced torque converter clutch and replaced battery terminals fixed the issue of dancing tcc for a few thousand miles now its back again. Could this be pcm related solely?
Old Feb 15, 2011 | 07:32 AM
Might be wiring between PCM and trans too....... Would be nice if you could do some data logging, and see what is going on when the condition presents itself.
