2001 Dodge Ram Turn Signal/ Brake Problem
Old Feb 15, 2011 | 07:35 AM
sdduke's Avatar
sdduke
Default 2001 Dodge Ram Turn Signal/ Brake Problem
When I apply the brakes on my truck with left turn signal on, the blinker stops working. I have swapped the rear brake light sockets (right to left) to see if it was a socket problem. Problem persists.
I have also replaced the multi function switch at the steering column.
Any ideas?
Thanks
David in Atlanta
2001 Dodge Ram 4x4
Old Feb 15, 2011 | 07:37 AM
Do the lights work normally independent of each other? I would suspect either a bad bulb, or, a bad ground.
Old Feb 15, 2011 | 07:56 AM
sdduke's Avatar
sdduke
The brake light and turn signal light are one in the same.
Old Feb 15, 2011 | 08:06 AM
zman17's Avatar
zman17
Retired Moderator - RIP
If you have trailer wiring check it all out.
