new build 440
Old Dec 6, 2010 | 01:39 PM
TheBigRedOne's Avatar
TheBigRedOne
he said the engine is coming with a transmission. a drive shaft should not be too hard to track down. i know on the older dodge trucks they had 2 different size of universal joints for the drive shafts and i doubt that has changed. it should not cost over 10k.
LOL. To get a custom driveshaft made/balanced will cost upwards of $500 at least. He will need full instrumentation will cost $700+. Gauges aren't cheap. The frame will need to be beefed up in the area of the motor mounts, and to do it at cost will be around $300 worth of steel, plus welding supplies and paint. Motor mounts if you buy prefabbed ones will be around $150, however since there is no such thing, those will be custom also. Fuel delivery system, ignition, wiring, hoses, cooling, and all other incidental expenses/supplies.
**** adds up really fast when you're doing custom work. I will stand next to that $10k figure all day long.
Old Dec 6, 2010 | 02:13 PM
crazzywolfie's Avatar
crazzywolfie
i know custom work is expensive but i am pretty sure you could re-use or find some of the stuff needed cheap. you might be able to use the old gauges with the 440. just leave the computer in and hot wire the engine and use the sensors from the 5.2. for the drive shaft you could probably find the right one in the junk yard if the stock one don't work. there is so many way to try saving money.
Old Dec 6, 2010 | 02:45 PM
TheBigRedOne
"Hot wire the engine", use a non existent driveshaft from a junkyard, using OBDII Gauges with a computerless engine, and use sensors a carbureted engine won't need..
Its really obviously you don't have a clue what you're talking about.
Old Dec 6, 2010 | 02:59 PM
crazzywolfie
you would not need all the sensors. you would only need some of the basic one like Coolant Temperature Sender, Oil Pressure Switch and Speed Sensor. you would only need to find a drive shaft if the stock one is not the right size.
Old Dec 6, 2010 | 03:07 PM
dodgetrucker75's Avatar
dodgetrucker75
correct! using the 96 stock sensors with the stock 96 wiring will make the gauges work, everything else can basically be cut off, it jest sets the CEL, but that is easy enough to remove from the dash as it will no longer be needed, i ran my cummins off the v-10 electrical, untill i was able to track down the correct stuff, not a problem one, just a CEL
Old Dec 6, 2010 | 06:36 PM
rollinlow's Avatar
rollinlow
http://www.engine-swaps.com/Pages/Pr...gConvKits.html
dont know for a fact how much a 360 mount differs from 72 to know but heres a start 3rd from the bottom for 2wd
if i rem correctly mopar action did this same swap 10 to 12 years ago may be able to do a search through the internet for the old issues
as far as the drive shaft issue hmm it really isnt hard to take a tape measure and the u joints to match everything up biggest problem making sure a junk yard shaft is prop balanced
Old Dec 7, 2010 | 08:12 AM
ddotson440's Avatar
ddotson440
I'm a welder at a structural steel plant so anything I need for mounts
And or frame beef is ..Shh... free hah and I also have a rig welder home In he Gerage.
Like I said I'm gonna run it like a 72.. so all I need for computer is what keep the motor turning
When I hit the go button haha maybe even a push start no key
It is a toy.
Thanks for the responses though I can't wait to et you guys some pictures to look at
