Please help a noob!
Old Dec 7, 2010 | 12:34 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You'll want to check all the ground wires, all the other directional bulbs, also the bulb sockets themselves and the trailer hitch wire harness if you have one.
Old Dec 7, 2010 | 12:38 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by J415
0443 is a real PITA to track down. I'm still trying to track mine down.
Clogged filter canister or possibly junk in the tubes. That's what's wrong with my truck. I just clear the code when it appears. I'll fix it (one of these days).
Old Dec 7, 2010 | 12:44 PM
J415's Avatar
J415
Canister is relatively new, purge solenoid is new. I'm gonna blow the tubes out next with my compressor next. Hope that works because the CEL is annoying the heck out of me.
Old Dec 7, 2010 | 12:46 PM
zman17's Avatar
zman17
If the old canister blew up and charcoal got into the vacuum lines, it may very well have gotten into the new solenoid.
Old Dec 7, 2010 | 12:59 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Hop-a-long has a good point.
Old Dec 7, 2010 | 01:04 PM
zman17's Avatar
zman17
Lol....
Old Dec 7, 2010 | 01:22 PM
LexBeBrolic's Avatar
LexBeBrolic
The canister is located under the truck on the driver side right? Is this thing easily replaced?
Old Dec 7, 2010 | 01:25 PM
zman17's Avatar
zman17
It is easily replaced, but first check and make sure it needs to be.
Old Dec 7, 2010 | 01:26 PM
On the newer trucks, it is on the passenger side, mounted outside the frame rail. Should be just under the back of the cab, take a peek, should be obvious.
Old Dec 8, 2010 | 12:30 PM
LexBeBrolic
Unbelievable...I went home yesterday and popped the hood. Sure as $H!^ there is the valve staring me in the face, exactly where it is in your picture. I have poured over my HAYNES manual to find this thing. My manual says and shows a diagram depicting the valve as attached to the throttle body. In reality it is no where near the the TB??
Now I unsure about using this Haynes manual for further repairs? This was a pretty big oversight...
On the other hand I removed the valve, banged it on the side of the truck a few times. Cleared the code, and put the old valve back (new one hasn't arrived yet)
I drove like crazy all day yesterday and the code never came back, incidently the truck didn't stall at a single red light either?
