High Idle
Old Dec 7, 2010 | 06:59 PM
Dantra's Avatar
Dantra
Default High Idle
After replacing a defective injector and TPS yesterday, my idle is very high (around 1000 in D) Is there something that needs to be reset or any other reason for this to happen? I wrote it off at first, that it was actually running on all 8. Is there a wrong way to install a TPS?
Old Dec 7, 2010 | 07:44 PM
Twisted Metal's Avatar
Twisted Metal
There is no real wrong way to install a TPS. Did you clear the ECM prior to restarting the truck after the parts where installed?
Old Dec 7, 2010 | 08:39 PM
dhvaughan's Avatar
dhvaughan
+1 on reset the PCM. disconnect negative battery cable and turn on headlights for 30 seconds. reconnect battery and fire it up.
Old Dec 7, 2010 | 09:01 PM
Dantra's Avatar
Dantra
Thanks...I'll give it a shot
