What is a similiar size to a 33x12.50x15 for metic?
Old Dec 8, 2010 | 12:56 AM
merc225hp's Avatar
merc225hp
Not sure what year but f150, whats "cheap" a number really helps, for wheels and tires?
Old Dec 8, 2010 | 01:33 AM
vikingdiesel's Avatar
vikingdiesel
the setup you have is perfect, those wheels, I have an 01, so whats the same? whats the width I should stick with, im def sticking with 33" tires since 35" will prob rub on my 2-3 inch lift, whatever I have not sure
Old Dec 8, 2010 | 01:59 AM
merc225hp's Avatar
merc225hp
Thanks, You can get those wheels for $109 each, but you can probably find them cheaper some were else I just did a quick price check and to see if they are still around. They are eagle alloy series 185 16x8 4" back space and -11 offset, 5 on 5.5 holes. I don't have anything good to say about these wheels or the warranty, look for better. Post/add a pic of your truck and someone will give you an idea how much lift is in it.
Old Dec 8, 2010 | 09:28 AM
redheadhunter21's Avatar
redheadhunter21
97 and older ford f150's have the same bolt pattern, suzuki samuri's and another suzuki suv thing forgot the name,
Old Dec 8, 2010 | 09:43 AM
Have look here.
Old Dec 8, 2010 | 11:13 AM
Gerehead8's Avatar
Gerehead8
The lug pattern is 5x5.5". It was a very common size for 1/2 ton trucks years ago and many other vehicles had it too. I am looking for a set for an '89 dodge and they are a dime a dozen on craigslist.
Factory wheel back spacing is about 5" or so depending on wheel. It is easy to measure a set of rims to determine if they will work.
The wheels that you are talking about are also sold as a summit brand wheel and may cost less.
As far as cheap goes, beggars can't be choosers. Buy whats cheap and available. If you are looking for something in particular, pay for it or expect to wait a long time. You could also look at swap meets and on ebay (best bet for something particular shipping is $$$ though).
