trans Problems FLM
Old Dec 8, 2010 | 01:57 PM
byronpen's Avatar
byronpen
Default trans Problems FLM
My 1999 dodge ram 1500 5.9l 4x4. I’m still having Tran’s problems, when I’m driving the rpm gauge, keep bouncing/shifting late, I used a tuner to raise the rpm limit, fixed the problem for a while, then my truck stops getting power to the wheels. I pull over let it sit for a bit, and I can drive again, WTF is wrong
Old Dec 8, 2010 | 02:11 PM
Might be TPS. Might be pressure sensor and solenoid in the trans.
Old Dec 8, 2010 | 02:15 PM
byronpen's Avatar
byronpen
elaborate, please picture, ect what Im looking for. How can you tell its bad ect
Old Dec 8, 2010 | 02:36 PM
byronpen's Avatar
byronpen
Is this one of the parts needed
http://shop.advanceautoparts.com/web...NAMS_560498095___
Old Dec 8, 2010 | 02:37 PM
TPS is on the drivers side of the throttle body. Throttle position sensor. Need a meter, or scanner to test. (or, simply replace it, and see what happens.)
(governor) Pressure sensor and solenoid are IN the transmission. Drop the pan, and they become visible. They are rather notorious for screwing up..... only way to really test them, (if you aren't getting codes for 'em) is to dig in, and inspect.
Old Dec 8, 2010 | 02:39 PM
Originally Posted by byronpen
I think that is the fourth gear shift solenoid, and that is for a trans without locking torque converter, so, no. Not the one you want.
Old Dec 8, 2010 | 03:14 PM
byronpen's Avatar
byronpen
Im pulling No codes. Could it still be the TPS
Old Dec 8, 2010 | 03:26 PM
Yep. Do you have a voltmeter available?
Old Dec 8, 2010 | 06:06 PM
95RAM360's Avatar
95RAM360
have you tried the key dance trick to try to pull codes?
