Heater not blowing hot
Old Dec 8, 2010 | 06:22 PM
justjoe906's Avatar
justjoe906
Default Heater not blowing hot
99 Ram 1500 V-8, heater does not blow hot air. Flushed out heater core with no luck.
Both of the inlet and outlet heater core pipe gets hot to the touch but heater not warm.
Thanks
Old Dec 8, 2010 | 06:28 PM
03neonSE's Avatar
03neonSE
Clean out blower motor. Mine was stuffed with leaves...
Old Dec 8, 2010 | 07:42 PM
Check and verify the temp door is doing what it should. Known problem with the coupler between the actuator, and the door.
