Radiator Flaps
Old Dec 10, 2010 | 04:04 PM
RamSport97's Avatar
RamSport97
Thanks Aim, I plan on building a Ram Air setup sometime in the near future, if I can, might just swing for it and get the Ram Air Box.
VW- It is basically gasket material that you can purchase at any auto parts store to make your own gaskets. The gasket material is basically the same material and thickness as the factory radiator flaps. This is what I used, its usually around 5 dollars, and comes in a 10"x26" roll, you will need two of them.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Gasket-Material-Felpro_5189950-P_N3540_A|GRP60025____
And I used regular body fasteners to secure them. They are the same plastic push rivets that come on the flaps from the factory.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Body-Fasteners---Interior-Trim-Panel-Retainer---Universal-Dorman---OE-Solutions_5029945-P_N3102_A|GRP2037____
Also wanted to note, as Twisted Metal said, they are also available through LMC truck, I just found it easier to lay the old perished flaps on top of new gasket material and trace them out. Save you some bones and shipping costs.
http://www.lmctruck.com/icatalog/de/full.aspx?Page=91
Old Dec 10, 2010 | 04:19 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Awesome. Yes, they're available through LMC Truck; however. it's a bit more convenient and economical to make one's own.
Old Dec 10, 2010 | 04:24 PM
RamSport97's Avatar
RamSport97
Exactly, not to mention the Right Hand side is back ordered .
Old Dec 10, 2010 | 04:45 PM
lastrights's Avatar
lastrights
mines been off for a couple years now
Old Dec 10, 2010 | 05:12 PM
PurplDodge's Avatar
PurplDodge
Mine have been off for several years now. No adverse effects on the engine cooling (and I tow!).
Old Dec 10, 2010 | 05:27 PM
grox's Avatar
grox
I also have no adverse effects without the flaps, and I live in Phoenix. Highs in the upper 70s and lower 80s this week
Old Dec 10, 2010 | 05:35 PM
DukesOfHazzard's Avatar
DukesOfHazzard
Seriously? rad flaps ? you ppl think ****s gonna hit the fan if you dont have them?!?!?!
Old Dec 10, 2010 | 06:50 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by DukesOfHazzard
Seriously? rad flaps ? you ppl think ****s gonna hit the fan if you dont have them?!?!?! thats a big ten four double u oh double u!!!
Detroit NEVER installs anything on a vehicle that's not needed. They're supposed to be there for a reason.
So----- back at'cha
Old Dec 10, 2010 | 07:26 PM
DukesOfHazzard
oh so the plenum was a friday job????????
Old Dec 10, 2010 | 07:44 PM
aim4squirrels's Avatar
aim4squirrels
The pan on the belly exists solely because of the ease at which things can fall into the manifold due to the TB sitting on the top of the engine, and that its a hell of a lot cheaper to cast a piece of aluminum that isn't fully enclosed. The steel pan on the bottom was cheaper than aluminum at that gauge which it why it isn't made of aluminum.
