Catalytic Converter Problem
Old Dec 11, 2010 | 11:51 AM
melsdually's Avatar
melsdually
Question Catalytic Converter Problem
I need a little help. There are no warning lights and the truck runs normal, but there is a loud knocking sound coming from the Catalytic converters. What would cause this, and how do I fix it. The only replacements I can find are somewhere between $500-$800 each. Any suggestions on what to do or where to get new ones?
Old Dec 12, 2010 | 05:55 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to Dodge Forum. I will move this to the 2nd generation Ram section (1994-2001 Rams), get you some answers.
Old Dec 12, 2010 | 06:12 PM
Do you have one cat? Or do you have california emissions?
Old Dec 12, 2010 | 06:38 PM
redheadhunter21's Avatar
redheadhunter21
If you dont have cali emissions, you should only have one cat....if so you can pick up a universal magnaflow cat for under $200, someone should have a link up soon, if you have the older style cat that also doubles as a y pipe you can get a shop to put a y pipe in and install the cat right after....if you have the newer style exhaust they can just cut the old one out and replace,(unless you can weld then you can do this yourself)
Old Dec 12, 2010 | 07:26 PM
99dodge318's Avatar
99dodge318
my stock cat is also the y-pipe, but jegs has off-road y-pipes for like $125, and cats for $120
its one of the items on my list
Old Dec 12, 2010 | 07:42 PM
dodgeman52's Avatar
dodgeman52
http://performance-curve.com/thunderbolt-spincat.aspx
Old Dec 14, 2010 | 03:30 AM
97ramlv's Avatar
97ramlv
i just took my cat off and special ordered a y pipe so i can get universal cat.
Old Dec 14, 2010 | 06:27 AM
newman1367's Avatar
newman1367
had same symtom on a 95, heat shield on cat vibrating causing the noise
