Question from TN
Old Dec 11, 2010 | 07:35 PM
Kornbread's Avatar
Kornbread
Default Hey From Sevierville TN
Hey Guys gotta question, I recently baught a 98 dodge ram 1500 4x4 and it only has 92k on it but its trans is acting up. As you drive down the road it wants to go in another gear as if your going to climb a steep grade and you mash the gas to kick it in another gear. It doesnt do it all the time but it is noticeable. Maybe Im being picky but also does Dodge Rams usually kick out of 4x4 mode past 30mph if its in 4high? Former Ford owner so Dodge is new for me.
Old Dec 11, 2010 | 07:58 PM
Your lifter rattle is actually spark knock, check your plenum, bet ya its blown. (plenty of threads on this issue, do a quick search.)
4x4 should stay engaged regardless of speed. If the lite is going out when you accelerate, you have vacuum issues. (which may be related to the blown plenum)
Get the engine running right first, and see if that doesn't improve the transmissions attitude as well. Did for mine.
Old Dec 11, 2010 | 08:21 PM
Gerehead8's Avatar
Gerehead8
What size tires and what gear ratio?
Old Dec 11, 2010 | 09:08 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Dec 11, 2010 | 09:14 PM
meanwhitemopar's Avatar
meanwhitemopar
Heyyou, first I have seen u, or its just i havent been on in a while, but u are right, all thoaw thinga uu put, sound correct. to the tee
Old Dec 11, 2010 | 09:34 PM
rollinlow's Avatar
rollinlow
welcome to the site from just down the road
