swapping a 318 out for a 360
Old Dec 12, 2010 | 09:38 AM
MathewsShooter's Avatar
MathewsShooter
Default swapping a 318 out for a 360
I have a 97 1500, how hard would it be to swap out the 318 for a 360? I'm worried about the wire harness, more than anything. Also anyone have a clue how much it would cost to have new bearings put in my 5.2? thanks Matt
Old Dec 12, 2010 | 10:17 AM
360 is a direct bolt in. Everything will swap right in. Use the sensor and such off of the 318, and get a new tune for the larger engine, and you will be right down the road.
If your 318 needs new bearings, it probably needs a lot of other things as well.... not an inexpensive proposition.
Old Dec 12, 2010 | 10:25 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Actually you can leave the sensors alone. What you need, is a PCM for a 360 that has close to the same options as your truck or install everything and get the truck to the dealer and they can flash it for a 360. Or get a good tuner as HeyYou has suggested.
Old Dec 12, 2010 | 11:07 AM
I like the tuner idea better, as you have fewer issues with annoying some of the other systems that the PCM talks to as well. On some, having a different VIN in the PCM will turn on the abs lite, and such. Cost is pretty relative here... if you can find a JY unit, its cheaper, but, you have the possibility of the aforementioned issues. The tuner kills several birds with one stone, as it were.
Old Dec 12, 2010 | 12:10 PM
lazyboy's Avatar
lazyboy
am in the very beginning stages of doing just this 318-360 swap. in my vetures of research I discovered the SCT tuner will do what we need for our pcm. the rest Im told is plug and play. cept mine is a 5 spd manual and donor is auto so am going to scrounge up a fly wheel.
got the tuner Fri and am playing with it on my 318 while i build the 360 the tuners are on sale this month and hemifever's service is second to none.
Doug
Old Dec 12, 2010 | 02:11 PM
hutch311's Avatar
hutch311
hemifever has the best deal for a canned tune sct tuner... and customer service is top notch
