Yep. If the low beams are on, the highbeams shouldn't be on at all.
see, in my case, when my low beams are ON, everything is ON, including the HI-BEAMS but when I go to turn the stalk to HI-BEAMS, it will get a TAD brighter, but still both lights are on
im betting the plugs got mixed up at some point..sounds alot like that..9007 and 9004 bulbs are grounded and powered differently but use the same plug as stated check the connections at the bulbs
Yup, the 9007 and 9004 plugs are identical in looks. Just wired differently.
The sockets/harnesses may or may not be colored differently.
Simple to troubleshoot though. Flip the two plugs on the driver's side around. No change? Flip the two plugs on the passenger side around also. No change? Flip the plugs on the driver's side around again.
I have simalar issue put the sylvania silver star bulbs in my 99 ram sport high beam indicator stayed on put the old bulbs in it works fine seems strange any idea's
Did you buy the right bulbs and put them in the right plugs? (See above posts for the ones you need.)
