Ecm & pcm
Old Dec 13, 2010 | 12:58 PM
coryjennings03's Avatar
coryjennings03
That it does! I'm just glad to hear that it is running with an acceptable oil pressure though. I may eventually switch to a high pressure pump though just to be safe. Now to get behind the dash, disconnect the check gauges bulb and the chime, and I am set! well except for the exciter ring in the rear diff.....damn abs system
Old Dec 13, 2010 | 01:08 PM
Just go with a high volume pump, you will get better pressure that way in any event, and the increase in volume isn't going to hurt you a bit.
Old Dec 13, 2010 | 01:10 PM
coryjennings03
Wouldn't I have to get a bigger pan to support extra oil so the higher volume pump won't suck my pan dry while I'm goin down the road?
Old Dec 13, 2010 | 01:12 PM
Nope. Not an issue for me at any rate.
Old Dec 13, 2010 | 01:19 PM
coryjennings03
well $45 isn't too bad for the high volume at both auto zone and checker auto parts...I'm currently running 5w30 in there right now...if everyone agrees that my oil pressure is normal than were set for now. Thanks everyone for the advice! saved me from replacing my computer (250+80 core...)
Old Dec 13, 2010 | 01:20 PM
coryjennings03
Sounds good, I'll have to get one ordered after xmas and wait for a day with decent weather to put the high volume pump in. Thanks for the advice.
