truck wont run help!
Old Dec 13, 2010 | 05:05 PM
bobracing32's Avatar
bobracing32
Default truck wont run help!
My 95 318 4x4 runs but after a couple minutes it spit and sputters then eventually dies. Then it will not start. If i wait an hour it will start. I need advice asap. thanks!
Old Dec 13, 2010 | 05:15 PM
Fuel pressure?
Old Dec 13, 2010 | 06:58 PM
bobracing32
now it idles at 1000, any ideas. I have not yet checked the fuel pressure.
Old Dec 13, 2010 | 07:10 PM
IAC. Possibly TPS. Could be any number of things. Need to know what you DON'T have, when it doesn't want to start. (fuel, or spark, or both)
Old Dec 13, 2010 | 08:12 PM
working4ev's Avatar
working4ev
I am with hayYou check the fuel pressure, It sounds like the truck is running out of fuel.
Possible causes
Fuel pump
Fuel pressure regulator
MAP sensor
TP sensor
Are you getting a check engine light? If so good this is a good place to start.
Old Dec 14, 2010 | 04:19 AM
bobracing32
Actually started it up and idled for a few minutes abd drove it. I imagine 20 miles or so and it ran great! Im thinking fuel froze. it was a high of negative five, today its around five above. I had two trucks that wouldnt run. Both got gas at the same store at the same time. Both wouldnt run. So im just thinking bad gas???
Old Dec 14, 2010 | 09:04 AM
cmckenna's Avatar
cmckenna
That is the most logical explanation. Put dry gas in all during the cold winter months from now on to prevent that issue.
CM
