transmission stuck in first
Old Dec 13, 2010 | 07:50 PM
chenchen's Avatar
chenchen
Default transmission stuck in first
Happened overnight.... no warning.
I have manual 1, manual 2 and reverse.
In drive it is stuck in first... wont upshift to 2 or 3 or overdrive.
Checked the fluid... Ok level and pink.
How far can I drive in first without harming anything?
Old Dec 13, 2010 | 07:58 PM
Don't over rev the engine, and you can drive cross country that way. Need to find out WHY it isn't shifting though...... Any check engine light?
Old Dec 13, 2010 | 08:24 PM
chenchen's Avatar
chenchen
Cross country sounds great.... island is 4 miles wide.
Check engine light and brake light have been on for 4 years after I accidentally shorted the ignition wires.
Corrosion is a serious problem here.... salt water... possibility??
Old Dec 13, 2010 | 08:36 PM
working4ev's Avatar
working4ev
Hi this may or not help.
Also how many miles are on the transmission? Because I had this problem just before my first transmission went south, But I had a check engine light something like governor solenoid pressure sensor code. I had to rebuild the transmission.
Have you replaced the fluid and filter lately? Remember use only ATF 4.
Pull the codes
turned the ignition off-on off-on off-on read the code that appeared in the odometer.
Old Dec 15, 2010 | 01:54 PM
chenchen's Avatar
chenchen
20,000 plus miles...... fluid and filter never touched in 10 years.
Fluid is pink.
Have appointment with shop next Monday.... not a transmission shop... there are none here.... big problems get crated and shipped off island.
Numbers in odometer read 27009.... is this a code or mileage?? ... did the on/off thing with the ignition.
Old Dec 15, 2010 | 02:34 PM
zman17's Avatar
zman17
Retired Moderator - RIP
That would be mileage. Now check for codes, as has already been suggested! https://dodgeforum.com/forum/2nd-gen...code-list.html
