cold weather and door latches
Old Dec 14, 2010 | 03:18 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by Eberron
Northern BC.
As for doors freezing shut, it's usually caused by water freezing the weatherstripping on the door to the truck. Maybe a thin coat of some kind of lubricant that the ice would not stick to as well? I have been meaning to try something for that myself actually.
Vaseline.
Old Dec 14, 2010 | 04:26 PM
99dodge318's Avatar
99dodge318
my door is hard to close unless you crack the window a little bit, i havent figured out if thats a good thing or bad thing yet
Old Dec 14, 2010 | 07:48 PM
merc225hp's Avatar
merc225hp
I have used spray silicon lubricant with good luck for the door seals.
Old Dec 15, 2010 | 02:44 PM
lvolson's Avatar
lvolson
A fellow in Advanced auto parts heard me talking about this subject. He recommended "Pledge". He said you could try armorall but pledge is cheaper.
On a semi related note, I just got done using a heat gun to defrost my window washers because it seems the fluid that was in there was regular summer time stuff. Yup... I had ti use a heat gun. I started it an let it run for a while but it's so cold out, the engine compartment just wasn't heating up enough. Too bad it's too late for me to ask santa for a car port or something I can enclose!
