4 cracked heads WTF
Old Dec 14, 2010 | 11:03 PM
Hahns5.2's Avatar
Hahns5.2
Magnums crack heads, just the way it is. I've never actually heard of cracked heads causing a problem in a Magnum V8..
Old Dec 14, 2010 | 11:20 PM
WhtDually95's Avatar
WhtDually95
very true, I havnt heard of problems niether. I am sure that there is a shocking amount of 318/360 heads out there that are cracked and we dont know it. But I couldn't put them back on knowing they were cracked, that would be like taking a shower and not changing your underwear.
Old Dec 14, 2010 | 11:26 PM
justfrfun's Avatar
justfrfun
Cylinder heads International. $375.00 for 2. UPS to you and you have 30days to send back your old ones. I have used these guys for all my dodge cracked head issues and have had none with them. As a matter of fact there are 2 of there heads setting on my slow going 360 block right now.
Old Dec 14, 2010 | 11:27 PM
justfrfun's Avatar
justfrfun
the ones I see, crack in between valve seats. can make for uneven compression.
Old Dec 15, 2010 | 02:33 AM
BlueBeast2's Avatar
BlueBeast2
CCH has HD heads. Heavy Duty upgrade that don't crack. You can find them on ebay or search them they have a site. You can get 2.02 valve heads for the price of the stock 1.92's. Like 750 for the set last I looked
Old Dec 15, 2010 | 08:26 AM
lazyboy's Avatar
lazyboy
the build is for torque and fuel mileage. if i understand correctly 202's wouldnt be a good fit for my app. thanks tho. sounds like a good price for hot rod heads.
Old Dec 15, 2010 | 09:58 AM
BlueBeast2's Avatar
BlueBeast2
Check with them anyway I got my heads through them and they are the 192's
Old Dec 15, 2010 | 12:34 PM
hometheaterman's Avatar
hometheaterman
This is true, but I've heard of it causing a miss that can't be tracked down.
Is there any part on this truck that isn't a design flaw? Other than maybe the front axle and that's because it's a Dana, not a Dodge designed part.
Old Dec 15, 2010 | 12:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The cigarette lighter seems to be pretty good.
Old Dec 15, 2010 | 12:44 PM
Funny, mine doesn't work.......
