I need a real dodge guru PCM TWEAKING ?
Old Dec 15, 2010 | 08:30 PM
socal101703's Avatar
socal101703
Default I need a real dodge guru PCM TWEAKING ?
I have a frankinstine truck but bottom line is im wondering if there is anyone out there that can program the ecu/pcm to think all the 02 sensors are on when there not ? SO need some major help to get my beast on the road?
Old Dec 15, 2010 | 08:53 PM
Why not just run the O2 sensors? You can get weld-on bungs for them.
Old Dec 16, 2010 | 07:52 AM
socal101703
Well my ecu is cali emissions so its looking for 2 sensors that are not on my federal truck. So i got a federal emissions ecu and my truck wont start. so the only way to keep my light off is to delete those sensors hopefully im in a big jam and i hate electrical
Old Dec 16, 2010 | 10:46 AM
TheBigRedOne's Avatar
TheBigRedOne
Those computers are not compatible with each other. CA trucks had different programming/outputs/emissions control devices. There really isn't any way to reprogram that computer as it is a ROM device. Something you could try though are 02 simulators. Unless you know how to play with resistors though, good luck.
Old Dec 16, 2010 | 10:58 AM
Get a PCM for the correct emissions installed on your truck. Install two O2 sensors, and be done with it. Cheaper, easier, and will actually work BETTER than any other solution.
I don't know of any company that has the ability to re-write the programming for the PCM. Not to mention, the legal ramifications of doing so...... (which is probably why you DON'T see any one doing it.)
