Pistons with HS 1.7's?
Old 12-19-2010, 11:55 AM
redheadhunter21's Avatar
redheadhunter21
redheadhunter21 is offline
Yeah if you change pistons your gonna pretty much have to pull the motor you dont even need to pull the heads for the rockers, just the valve covers
heres my comparison
since your changing your lug nuts you mght as well change out the ring and pinnion for a new set of 3.55's
Old 12-19-2010, 12:09 PM
drewactual's Avatar
drewactual
drewactual is offline
Like I said before, that friend of his need to be consulted for mechanical advice no more... It's hilarious when a persons ignorance gets in the way of their pride- but it's downright dangerous when someone who supposedly 'knows', causes you HUGE grief because of their pride..
They call that an @$$ whoopin' where I'm from..
Old 12-19-2010, 02:08 PM
CPTAFW163's Avatar
CPTAFW163
CPTAFW163 is offline
pistons are not easy to do. You will buy the pistons, then the $150 gasket/seal set, then new rod bearings, then new rod bolts...oops forgot the piston rings.
not only 200 bucks.
Old 12-20-2010, 12:25 PM
bmyze316's Avatar
bmyze316
bmyze316 is offline
yeah thats why I posted the question on the forum. dodge forums take out all the guess work and prove alot of people who think they know what they are doing wrong. Thanks everyone I'll stick with the rr's only.
Quick Reply: Pistons with HS 1.7's?
