rear tire/wheel play....
Old Dec 17, 2010 | 11:34 PM
offroadjosh's Avatar
offroadjosh
Default rear tire/wheel play....
Jacked up the rear end today(had to chain truck up and go chew the solid ice driveway up). Anyway jacked rear end up and as i was getting ready to toss the chains on i pushed again the driver side rear tire and noticed a very slight amount of play(enough to make a noise like the brake drum is moving) but not enough to feel.. Got me curious sooo i went to the pass side.. and same exact thing. Is this a bad sign? or is this normal? Im pretty worried....
Old Dec 18, 2010 | 07:18 AM
95RAM360's Avatar
95RAM360
ive never noticed on mine......but having play cant be good.....since its a straight axle with no options for a flex (unlike the front)......id go into depth with it and check everything out to be safe.
Old Dec 18, 2010 | 07:42 AM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
josh, was this on your 1500 axle? if so it may be the play in your axle housing with the axle shaft. also it could be rear wheel bearings. id keep an eye on it, but wouldnt get too nervous over it.
Old Dec 18, 2010 | 10:32 AM
Aren't those C-clip axles? (axle held in place by a clip on the differential end.) If so, a LITTLE bit of movement is typical.
Old Dec 18, 2010 | 11:16 AM
offroadjosh
Thanks guys, i'm pretty sure it is a c-clip style, so that would make sense.. But i will be keeping an eye on it just to be safe.
Old Dec 18, 2010 | 11:44 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Normal, nothing to worry about.
Old Dec 18, 2010 | 03:02 PM
dhvaughan's Avatar
dhvaughan
9.25 is a c-clip axle and about 1/4 inch in/out movement is normal.
Old Dec 19, 2010 | 12:47 AM
offroadjosh
Glad to hear! Thanks for saving me a bunch of worry!!!
Old Dec 19, 2010 | 03:03 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Pee down your leg a little did we? lol.
Old Dec 19, 2010 | 09:24 AM
xxxcowxboyxxx
thats what i figured, thats why i was wondering if it was the 9.25 axle. i would have been a bit worried if it were the dually axle
