blower motor stays on when ignition is off!
Old Dec 18, 2010 | 12:38 PM
Steigl1's Avatar
Steigl1
Default blower motor stays on when ignition is off!
I shut the ignition off and take the key out, and the blower motor will stay on! i can shut it off if i turn the climate control **** to off. and the fan speeds all work... i swapped out the blower motor relay and that didn't help. i thought maybe blower motor resistor? but people tell me you usually lose fan speeds when that goes bad. any ideas?
99 ram 1500 4x4
Old Dec 18, 2010 | 12:45 PM
Check and see if you have power at pin 86 of the blower motor relay with the ignition off.
Do any other accessories still work with key off?
Old Dec 18, 2010 | 01:52 PM
Steigl1's Avatar
Steigl1
i get 5.3 volts on pin 86 with ignition off. and i just noticed if i turn off the ignition real slow the blower motor shuts off.. no other accessories are on. i wonder if a bad ignition switch would do this?
Old Dec 18, 2010 | 02:55 PM
Thats what I was thinking, but, I would think that more than just the blower motor would be affected....... But, the fact you are getting power there does kinda indicate a failing switch there......
