'99' 1500 billowing white smoke
Old Dec 18, 2010 | 02:05 PM
mr wendy's Avatar
mr wendy
Default '99' 1500 billowing white smoke
Got a '99' 1500 w/5.2. Been losing a lot of brake fluid about a quart a month.Can't find the leak.Checked the lines,slave cylinders,calipers,master cylinder everything...Now the truck is billowing white smoke and missing a little.Coolant and oil good no mixing and not low.Is it possible the brake fluid is leaking at the master cylinder and being drawn into the intake by the vacum line.
Thanks
Old Dec 18, 2010 | 02:23 PM
matty675's Avatar
matty675
sounds about right, first unhook the line from the manifold and look for traces of fluid, if fluid is found replace the MC and probably the booster too
Old Dec 19, 2010 | 09:46 AM
mr wendy's Avatar
mr wendy
Sounds like a direction to go..Wasn't thinking about replacing the boostrer but probably would be better...
Thanks
Old Dec 19, 2010 | 09:50 AM
brake fluid will do a number on the bladder in there.....
Old Dec 19, 2010 | 12:50 PM
matty675's Avatar
matty675
how are the brakes themselves working?
Old Dec 23, 2010 | 10:45 AM
mr wendy's Avatar
mr wendy
Default 99 1500
The brakes are working normal.But I have never really liked them since I bought it new.Takes way to much pressure to stop...
Old Dec 23, 2010 | 10:51 AM
It sounds for all the world you like have a blown master cylinder though. That is the only way you could get fluid thru the booster, into the intake manifold. Have you checked that hose? Find anything interesting?
If you do find evidence of fluid in that hose, swap the master, AND the booster. I suspect your brakes will work better for ya.
Old Dec 24, 2010 | 05:57 PM
mr wendy's Avatar
mr wendy
Default 99 1500
Pulled the master cyl off booster was completely full of fluid..Ha Ha ....
Swapped them out less smoke but afraid I have more going on.Code reader shows misfire on #5 gonna have to dig deeper.
But after Christmas..
Merry Christmas
Thanks for the help...
