Checked the light code.....
Old Dec 18, 2010 | 05:52 PM
Jeffress77's Avatar
Jeffress77
Default Checked the light code.....
Here is what it said...
Evap Emission Control System Purge Valve C Fault
What does it mean?
Old Dec 18, 2010 | 06:05 PM
Circuit fault. What is the actual code?
Old Dec 19, 2010 | 01:04 AM
Jeffress77's Avatar
Jeffress77
Code was 0443 which reads: P0443 Evap Purge Solenoid Circ
I recently chaged the a/c evap. core and heater core. The a/c is still completely uncharged. Could this be the culprit?
Old Dec 19, 2010 | 07:14 AM
Nope. PCM doesn't care about whether the A/C works or not.
Your purge solenoid is up on the passenger side, toward the front, right in front of the wheel well. PCM thinks there is an issue on that circuit.
There is a factory service manual for the 01 trucks in the faq section here, I recommend you download that, and have a look. At least, it can give ya pics of where things are. Problem might be obvious......
