wont crank help
Old Dec 19, 2010 | 05:33 PM
ostrx250's Avatar
ostrx250
Default wont crank help
neighbor has a 97 2500 good battery smoked cab ground on left side melted a vac line has good battery but start relay just busses anyone have a trouble shooting guide
Old Dec 19, 2010 | 05:54 PM
did you fix that ground?
Old Dec 19, 2010 | 06:45 PM
ostrx250's Avatar
ostrx250
yes no change relay just busses like its bad switxh it with another no change
Old Dec 19, 2010 | 06:51 PM
Swap the starter relay with another one, give it a shot.
Old Dec 24, 2010 | 01:25 PM
ostrx250's Avatar
ostrx250
already did no changed think i found the problem solinoid wire and pos cable at starter were arcing plastic is melted does anyone know of any fusable links i wish he had a shop manual or something to refer to he took it to a gas station they havent touched it in 2 days no they are not busy
Old Dec 24, 2010 | 01:58 PM
There may be a fuse in the PDC. (power distribution center, up on the drivers side fender well, right behind the battery.)
There is a 2001 factory service manual available for download in the faq section here. wiring diagram for starter should be accurate for you.
Old Dec 26, 2010 | 10:57 AM
ostrx250's Avatar
ostrx250
yea i was hoping for a schematic to the relay i believe the wire was backfeeding the ignition no fuses blown pds box i didnt see any fusable links darn kids at work everytime i have a chance to look at it i havent been able to check voltage during start cycle other then battery, got a friend says he may be able to access alldata for the info
