On the gas...loud - off the gas...not so loud = bad pinion bearings. You may as well change out the carrier bearings while you're in there because all the metal filings from the pinion bearings have contaminated the diff fluid and have caused some damage to those also.
sweet thanks guys, any idea where i should route wires, jus picked up old kc hilites and thinkin of wiring in today jus not 100% where to put em, any thoughts? i was thinkin jus bolt thro the top of my stock bumber.
