stuck key
Old Dec 19, 2010 | 10:01 PM
dipsherry's Avatar
dipsherry
Default stuck key
ok so today got home from school and went to pull key out of ignition and it was stuck. I wiggled it and tried to put the key in acc... spot it wont turn back that far i dont know whats going on. i thought about just getting a new igniton switch and lock cylinder. it is not a huge deal i just lock the doors and left the key in it but i dont want someone to walk by while i am at school or work and get any ideas. I pulled the covers and looked at the ignitinon it seems easy to change
Old Dec 19, 2010 | 10:29 PM
offroadjosh's Avatar
offroadjosh
push forward on the shift lever, sometimes mine sticks and i cant take the key out...
Old Dec 20, 2010 | 08:47 PM
dipsherry's Avatar
dipsherry
yeah tried it. The key now just pulls out with the inside part of the lock cylinder lol now i guess it is defiantly time to replace it
Old Dec 20, 2010 | 11:50 PM
DukesOfHazzard's Avatar
DukesOfHazzard
my other dd ,I'll be driving along and the keys will just fall out of the ignition on the floor, just a little wore out, lol comes in handy sometimes to being able to take the keys out while its still running
Old Dec 21, 2010 | 08:28 PM
dipsherry's Avatar
dipsherry
yeah i would mind it if just the keys fell out but my whole lock cylinder falls out lol prolly wouldnt look good getting stopped by the cops either
Old Dec 21, 2010 | 08:37 PM
So long as the name on the registration matches the one on the drivers license.....
Just don't forget your wallet. That would be fun to explain. (for certain values of fun.....)
Old Dec 21, 2010 | 08:52 PM
CPTAFW163's Avatar
CPTAFW163
have you checked to see if you did not turn the key ALL the way back. You know, there is a setting for you to just run your accessories (radio). Instead of turning your key to start, you turn it BACK to run accessories. You will not be able to pull it out like that.
nevermind, I read through your whole post :P
Old Dec 21, 2010 | 11:33 PM
KSteng89's Avatar
KSteng89
Haha, i had this same problem when borrowing my friends durango. I fumbled around with it for a about half an hour until i noticed i that i wasnt completely in park... i laughed at my ignorance after getting the key out.
Old Dec 22, 2010 | 03:33 PM
dipsherry's Avatar
dipsherry
i just ordered a new lock cylinder and ignition switch i figured they would sell it together but nope seprate and i am not sure how much fun it is going to be to get it to go back together but i will let you guys know
Old Dec 22, 2010 | 03:43 PM
squarebit's Avatar
squarebit
You probably had your wheels cranked when you turned it off, no?
The pressure on the steering will needs to be relieved before you can turn the key to the lock position. Turn your wheel a bit in the direction it moves.
