Headlight Restoration
I used, okay my fiance used, the Turtle Wax Headlight Lens Restoration kit today on my truck. My lenses were HORRIBLY yellowed.
Contents of kit:
BEFORE:
passengers side
drivers side
AFTER:
passengers side
drivers side
In my honest opinion, not bad for $8 and a huge difference. Waiting to see what a difference it makes when I go outside and look at the lights. But it is way too cold for me to want to do it right now.
Contents of kit:
BEFORE:
passengers side
drivers side
AFTER:
passengers side
drivers side
Tip-- follow directions. I only sprayed the lenses with invisible glass and did step one (rubbing compound). We did NOT have to sand the lenses at all. If they go bad again, I will just be buying rubbing compound.
And I went outside and turned my lights on... AMAZING output difference. Next change--brighter bulbs.
That's the plan. However I got pissed the other night because I couldn't see for crap and decided something had to be done. Once we get back from Michigan, and it warms up, we plan on it. Until then, this is a MAJOR improvement.
Trending Topics
You should do your fog lights too. Or remove the Sport headlights and send them to me. I'll send you some (Far from) perfect SLT lights!
Well, being a old body man I can tell you how to do this and it will work every time. Take 1200 wet and drie sand paper and keep it wet. After the sanding take rubbing compound and a buffer if you have one to buff out the sand makers. You can do the compond by hand just takes longer. They will look like new when your done. I like the 3M compound myself.
