t-stat
Old Dec 22, 2010 | 02:09 AM
offroadjosh's Avatar
offroadjosh
Default t-stat
How hard is it to replace the t-stat on these trucks?
Josh
Old Dec 22, 2010 | 07:56 AM
ferguson30's Avatar
ferguson30
Well, it only took me about 5 minutes to do mine, but that was only because I had the intake manifold off for the plenum fix...
To get it to the point you can properly see the surface, and clean them for the new gasket -
Drain the antifreeze down to keep from making too big of a mess
Remove fan belt
Remove alternator
Unhook AC compressor and swing over to passenger fender
Remove bracket for alt & AC
Thermostat is right there.
Probably half hour to get down to a good spot to work on it.
Old Dec 22, 2010 | 08:43 AM
Don't break any bolts though. That tends to add significantly to the required time to completion.
Old Dec 22, 2010 | 10:41 AM
offroadjosh
Damn thats a lot of work to replace the tstat! Maybe I oughta order a full tune up kit, plenum, serp belt, and rockers... And just wait till spring.
Old Dec 22, 2010 | 11:03 AM
Sheriff420's Avatar
Sheriff420
It ain't that hard https://dodgeforum.com/forum/2nd-gen...t-install.html
Old Dec 22, 2010 | 11:31 AM
DukesOfHazzard's Avatar
DukesOfHazzard
20-30 min thats the way i do mine
Old Dec 22, 2010 | 12:19 PM
PurplDodge's Avatar
PurplDodge
An extra 5 and an extra 5 less if you take the alternator out.
Old Dec 22, 2010 | 12:59 PM
drewactual's Avatar
drewactual
grind that dang tab off the neck and you're set for a five minute job for future changes.
Old Dec 22, 2010 | 06:18 PM
offroadjosh
Tab..?
Old Dec 22, 2010 | 07:25 PM
PurplDodge's Avatar
PurplDodge
Originally Posted by offroadjosh
Tab..?
Dont listen to them. I've replaced my thermostat many times and have never seen the reason to why they grind the tab off.
