Engine or Tranny pull
Old Dec 26, 2010 | 12:44 PM
TruckinDodge's Avatar
TruckinDodge
Default Engine or Tranny pull
For Christmas my truck decided I hadn't paid it enough attention so the throughout bearing went out. I now find my self in a struggle between pulling the engine forward and replacing the motor mounts while I'm at it or pulling the drive line the transfer case and the tranny.
I have a cherry picker but no transmission jack and I'm leaning toward using an intake plate adapter to support the engine and just pulling the radiator to pull the engine forward and replace the bearing but I have never used this type of adapter to hook my cherry picker up before.
Any way let me know what you guy's think please.
Old Dec 26, 2010 | 02:14 PM
matty675's Avatar
matty675
the kegger wont support the engine, or its atleast not reccomended.
just lift it out by the motor mounts
Old Dec 26, 2010 | 09:54 PM
TruckinDodge
Thanks Man that's what I was worried about. Well that and the fact that I still wonder if I'm crazy to pull an engine rather then the tranny LOL.
Old Dec 26, 2010 | 10:10 PM
J415's Avatar
J415
Why not just rent a tranny jack. There only around $30 a day.
Old Dec 26, 2010 | 11:13 PM
dodgeram07's Avatar
dodgeram07
man all we do i cut out a piece(thick) wood and adpt it to are floor jack,run a bolt though it and a racth strap, works good, also works good droping fuel tanks
also if you have more than one jack helps sum times
aslo a ideas
http://www.harborfreight.com/catalog...smission+jack+
Old Dec 26, 2010 | 11:37 PM
TruckinDodge
I don't live in CA anymore so it's going to be 20-30 degrees and I don't feel like laying on the ground that damn long. All the damn linkage and vacuum lines laying underneath the truck I'd rather just work from above as much as possible plus I get to change my engine mounts while I'm at it.
Old Dec 27, 2010 | 07:06 AM
95RAM360's Avatar
95RAM360
im just backin up the kegger part.....its not a solid piece of the truck.....when i removed my manifold to put my new one on, i used a RUBBER mallet to knock it free, and it broke a hole in it.....so that can tell you how weak they are....
Old Dec 27, 2010 | 07:17 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I would personally lie on the ground. A manual tranny is easy. Compared to pulling the motor. And good luck getting it lined back up correct.(clutch alignment tool). You'll still be on the ground doing the bell housing bolts, which will be alot easier without the tranny in the way.
Old Dec 27, 2010 | 01:56 PM
J415's Avatar
J415
Couldn't agree with you more zman.
Old Dec 27, 2010 | 09:22 PM
UnregisteredUser's Avatar
UnregisteredUser
I haven't pulled the engine from one of these, haven't even thought about it enough to go looking at what's required... but in the past, when given the choice I'd lift the engine every time rather than drop the transmission. It's usually easier and safer, and not so miserable when it's cold out.
If you go that route, please report back how painful or painless it was.
