No Torque Converter Lockup
Old Dec 3, 2014 | 09:43 PM
RamII59's Avatar
RamII59
I have P0442 and P0455 codes (EVAP codes that I've known about for a little while) showing with the key trick. I just bought an Innova code scanner to retrieve any pending codes and got P1740. I kinda wonder if these codes are related, as if the PCM is looking for a particular vacuum signal to engage TCC lockup.
Truck info: 5.9 liter, harland sharp 1.7 rockers, timing advanced via crank position sensor, reamed out throttle body, 4.55 rear gears, custom 3"single pipe exhaust, 180* tstat, and other little things.
Old Dec 4, 2014 | 07:42 AM
P1740 TCC or O/D Solenoid Perf
There ya go.... Check all the connections first, at the trans, and also check the PCM connectors.
Old Dec 7, 2014 | 08:20 PM
RamII59's Avatar
RamII59
Well, I dropped the tranny pan and found broken pieces from the boost valve, this being part of the lockup circuit. See this video:
Anyone know where I can get an upgraded boost valve assembly in Ontario, Canada? And, has anyone here ever put a rod in place of the accumulator spring for firmer shifts?
Thanks in advance!
Old Dec 7, 2014 | 08:33 PM
Try WITTRANS.COM
I dont know if they ship to canada or not..... I would think they do.
