Transfer case blues
Old Dec 29, 2010 | 11:31 AM
y2kram1500's Avatar
y2kram1500
Default Transfer case blues
1st problem
I have a 2000 ram 1500. The original TC, which is a 231D, works fine in 2 WD, however when shifting to 4WD hi or low all I would get is no movement and a loud growling sound. Does this sound fixable? or should I break down and get one from the boneyard for 350 bucks?
2nd problem
I got another TC that was supossedly rebuilt. But the shift pattern is completely different. Is it possible that whoever the rebuilder was to have put something in backwards? Or were the earlier TCs that much different? I think it was from a '98.
Thanks for any info
Old Dec 29, 2010 | 11:48 AM
matty675's Avatar
matty675
the t-cases were different from 94-97 and 98-01
is 4wd fully engaged and the truck wont move?
Old Dec 29, 2010 | 12:00 PM
y2kram1500's Avatar
y2kram1500
Yes, no movement, just growling. Like gears that were almost meshed, but not enough to get a bite
Old Dec 29, 2010 | 12:05 PM
but it works in 2wd????? I would be REAL suspicious about that...... better drop the rear drive shaft, and see how much movement you get in the rear output shaft on the t-case. I suspect you have some internal issues there.....
