Headers
Old Jan 3, 2011 | 03:32 PM
  #31
merc225hp's Avatar
merc225hp
Quote:
FPRIVATE "TYPE=PICT;ALT=View Post"
When it comes to headers you get what you pay for, cheap headers= lots of problems down the road and during the install. I have had the Gibson headers on for over 4 years now, no leaks, no retighting the bolts, no blown out gaskets, no miss matched y pipe problems. I installed them once and have never had to touch them agine, 100% problem free.
Quote: You just jinxed yourself. Don't be shy about putting a new thread on here when they start leaking or develop cracks
I not shy about anything, If i have something good or bad to say about a product I will let you know about it, If something goes araye with them I will be the sure to post it.
Old Jan 3, 2011 | 03:36 PM
  #32
Sheriff420's Avatar
Sheriff420
the idea behind header wrap is to reduce under hood temps.... giving you a cooler air charge. Also supposedly helps with scavenging, by holding the heat in..... or something.
It will also save your spark plug boots from melting but it's better to get the boot protector deals (also made by DEI) since rubber won't rust.
I forgot to mention that I checked my headers vs. my dads manifolds temperature with a heat gun from the same locations, meaning:2" away, 4" away, 6" away and about 12" away.
Old Jan 3, 2011 | 06:00 PM
  #33
talon6's Avatar
talon6
edelbrock ceramic coated shorties,remflex gaskets and stage8 locking header bolts is what i have. 2yrs no problems. small gain in the upper rpms. didnt seem to loose any on the bottom.
Old Feb 17, 2011 | 09:08 PM
  #34
golfertexas's Avatar
golfertexas
Have a set of Gibson Shorties 1649s for 4.7L if anyone intereseted, email me at golfertexas@yahoo.com
Old Feb 24, 2011 | 09:39 AM
  #35
weedahoe's Avatar
weedahoe
Hall of Fame Member
We have a dedicated classifieds section. I suggest you use it and not post things for sale on other persons threads. Some people dont like it and get offended
Old Feb 24, 2011 | 09:47 AM
  #36
redheadhunter21's Avatar
redheadhunter21
its not even in the right gen
Old Feb 24, 2011 | 08:09 PM
  #37
jpoole's Avatar
jpoole
Gibson stainless shorties here. No problems w/ the EGR on my 95 and I have no leaks after 6 months or so. I had to do Mopar PCM as I have 95, added a Volant CAI, new stainless Magnaflow cat setup and a dynomax muffler with dual pipes and I can really feel the difference. Night and day or like a trigger job on a 1911...
Old Feb 24, 2011 | 10:12 PM
  #38
Josh_Putman's Avatar
Josh_Putman
Originally Posted by 99dodge318
i never thought about the wrap holding water and rusting. it would have been a hassle anyways, having to remove the plugs, wires and unbolting the headers. then wrap them and reinstall
If you are worried about the wrap holding water, just wrap some plastic sheeting over it and use some duct tape to secure it. It will keep the water out for sure.
You'll just never be able to drive it.
Old Feb 25, 2011 | 12:16 AM
  #39
TLars's Avatar
TLars
How about a new set of JBA stainless shorty headers for 250? Is that good?
Old Feb 25, 2011 | 12:20 AM
  #40
97Rampowerhouse's Avatar
97Rampowerhouse
Sounds like a Hell of a deal better snag them up. Considering else where they are going for 450 range!
