Headers
Old Jan 2, 2011 | 03:51 PM
  #21
dodgeman52's Avatar
dodgeman52
with my shorties i have put two sets of header gaskets within six months and there leakin again but these time im gonna but reflex gaskets in them and see how they hold up
Old Jan 2, 2011 | 04:15 PM
  #22
Some locking header bolts would probably help as well.
Old Jan 2, 2011 | 04:28 PM
  #23
dodgeman52's Avatar
dodgeman52
yea im thinkin about that also what im using now is bolts with small flat washers and lock washers and checkin the tightness of them every oil change
Old Jan 2, 2011 | 05:26 PM
  #24
merc225hp's Avatar
merc225hp
When it comes to headers you get what you pay for, cheap headers= lots of problems down the road and during the install. I have had the Gibson headers on for over 4 years now, no leaks, no retighting the bolts, no blown out gaskets, no miss matched y pipe problems. I installed them once and have never had to touch them agine, 100% problem free.
Old Jan 2, 2011 | 06:17 PM
  #25
Adobedude's Avatar
Adobedude
Originally Posted by drewactual
I've went on and on about this ad nasium, but the factory Y is the problem imHo.. that junction is choke central.. I really wish I would have taken a moment to snap a pic of it when I cut it open..
Now this is just me, so take it fwiw- but I did shorties first.. then later went back and made true duals.. I noticed a difference in tone with the headers is about all.. I notice a pretty substantial gain when I dumped the Y and went to a magnaflow true x muffler..
I'm thinkin- and again this is just my opinion.. that instead of doing shorties- get the Y replaced with a better rig and you will notice at least as much gain by itself as shorties net you.. You can always go back later and do the shorties.. that factory Y is a joke.
I agree 100%. Not much sense in going to a little 1-5/8" shortie unless you can get some decent ones like Gibsons for 50 bucks off EBAY
The real restriction is the Y-Pipe...And the stupid small 2" pipes.
Magnum motors like to breathe...
Old Jan 3, 2011 | 12:02 PM
  #26
Saber6's Avatar
Saber6
I bought the Hedman shorties. I have to tighten the bolts every six months or so. They are a thinner guage metal than most. I wish I would have noticed that when I made the purchase. No problems with the install.
No cracks so far. And as for tightening every six months... that's not too bad.
I really didn't notice any power gain when I put them on.
Old Jan 3, 2011 | 02:56 PM
  #27
Sheriff420's Avatar
Sheriff420
Originally Posted by 99dodge318
you wont be able to tell soon cause im gonna get some DEI header wrap to match my spark plug boot protectors. <--- also a good purchase if you get shorties
My headers are the same temperature at idle as my dads stock manifolds on his 5.9l. Header wrap is a waste of money and a good way to encourage rust.
Originally Posted by Thejudge02
Why did you have to do so much to the Y pipe?
It didn't match up to the headers, it was too wide. There weren't any leaks after I tightened the bolts though. And when I took the y-pipe off after a few years it held its shape (didn't spring back out too wide).
You just jinxed yourself. Don't be shy about putting a new thread on here when they start leaking or develop cracks.
Old Jan 3, 2011 | 03:02 PM
  #28
drewactual's Avatar
drewactual
I have the Hedman shorties too.. Didn't notice any gains until I dumped the Y and went true dual.. I'm hoping they hold up a while, but when their time comes- it will be ceramic coated long tubes.. I'm done putzing around with stuff- I want it to work, and to last.
Old Jan 3, 2011 | 03:12 PM
  #29
99dodge318's Avatar
99dodge318
i never thought about the wrap holding water and rusting. it would have been a hassle anyways, having to remove the plugs, wires and unbolting the headers. then wrap them and reinstall
Old Jan 3, 2011 | 03:14 PM
  #30
the idea behind header wrap is to reduce under hood temps.... giving you a cooler air charge. Also supposedly helps with scavenging, by holding the heat in..... or something.
