trans noise?
Old Jan 2, 2011 | 11:44 PM
69skylark's Avatar
69skylark
Default trans noise?
on these cool morns my tranny howls when i put it in reverse.after its warm its quiet.any ideas?
Old Jan 3, 2011 | 12:06 AM
Check fluid level.
Does it still make the noise if you immediately put it in neutral?
Old Jan 3, 2011 | 06:21 AM
95RAM360's Avatar
95RAM360
could it be a bad fan clutch....fan clutch will roar if it hasnt engaged yet.
are you sure its the tranny?
Old Jan 3, 2011 | 09:27 AM
69skylark's Avatar
69skylark
fluid is good,not the clutch fan,yes it stops in nuetral.
Old Jan 3, 2011 | 09:34 AM
dipsherry's Avatar
dipsherry
my truck does it my brothers ram does it but only in reverse i have heard its a common problem for the trans to make a little noise in reverse...is it worse when u put it under a load mine does it really loud when i am backing up my trailer
97Rampowerhouse's Avatar
97Rampowerhouse
I have the same damn problem with mine it kinda sounds like the powersteering is low and makes the noise but powersteering fluid is fine
I just put new filter and fluid in my trans still does it its annyoing!!!!
Oh yeah and when you put it in nuetral it stops
Old Jan 3, 2011 | 09:49 AM
97Rampowerhouse
Mine gets louder the more throttle you give it but if you mash on the loud pedal fast it stops for a second
Old Jan 3, 2011 | 02:20 PM
69skylark's Avatar
69skylark
yep thats the noise
Old Jan 5, 2011 | 04:27 PM
BamaRam97's Avatar
BamaRam97
Default Reverse Noise
I have the exact same problem. I've been told several vague ideas that it has something to do with the level of fluid with at start up. If anyone has any insight it would be very appreciated.
