vibration issue
Old Jan 3, 2011 | 03:43 AM
Ramtough96's Avatar
Ramtough96
Default vibration issue
i have 96 ram 1500 4x4, and when u start the truck when it's been sitting for a few days it will vibrate for a mile and half driving then stop and work fine. Also when you start the truck the 4x4 indicator light will come on when u start driving it will go out, but when you start slowing down it will flicker. I have checked for vaccum leaks and couldnt find any, i have checked indicator switch and cleaned it, and i have replaced the u-joints and cv joint on the front axle. And still it will vibrate!!!! I am at my wits end trying to figure out whats going on with this truck. Also tires are brand new, and has had a four axle aligmnent.
Old Jan 3, 2011 | 10:47 AM
do you feel the vibration thru the steering wheel, or the seat?
Are you sure the flickering light isn't your Low Washer Fluid light? (don't ask me how I know this.....)
Old Jan 3, 2011 | 02:00 PM
Ramtough96's Avatar
Ramtough96
Vibration seems to be coming from steering, if i have coffee in the holder it will vibrate with the truck. And no never checked the washer fluid, but after i read your reply i checked and its half full.
Old Jan 3, 2011 | 02:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Does it do this all the time? Or only when in 4wd?
Old Jan 10, 2011 | 02:39 AM
Ramtough96's Avatar
Ramtough96
Thats the problem when its in 2wd its vibrates for the mile and half but if i put it in 4x4 it works fine and no vibration till i put it back in 2wd.
