1996 trans swap with a 1994
Old Jan 3, 2011 | 05:59 PM
Ramster32's Avatar
Ramster32
Default 1996 trans swap with a 1994
I have a 1996 1500 ram 4x4 ext cab with the 360 motor. The trans went out about a year ago. I just ran across a trans out of a 1994 thats 4x4 with the 318 in it. I didnt know if it would work or not??
Thanks
Old Jan 3, 2011 | 06:00 PM
Nope. 94 trans is 46RH, 96 trans is 46RE.
Old Jan 3, 2011 | 06:01 PM
grox's Avatar
grox
In theory, the RH will work in place of an RE, but not the other way around
Old Jan 3, 2011 | 06:04 PM
Possibly...... not sure if you would get 4th gear, or TCC engage though, and it WOULD set the CEL on......
Old Jan 3, 2011 | 06:36 PM
Ramster32's Avatar
Ramster32
Ya thats what I was thinking but I ran across this site http://www.txchange.com/id.htm. It shows the 96 had the 46RE and the RH.
Old Jan 3, 2011 | 06:53 PM
That shows a year range..... dodge switched from the RH, to the RE in 96, same time they went from OBDI to OBDII.
Old Jan 3, 2011 | 07:44 PM
matty675's Avatar
matty675
simply put, DONT
