DIY Homemade Plenum Plate
Old Jan 24, 2012 | 08:24 AM
  #101
Augiedoggy's Avatar
Augiedoggy
I also wondered about the gasket being "pushed" the wrong way...it would be interesting to see your findings...
Old Jan 24, 2012 | 09:37 AM
  #102
W8 a minute's Avatar
W8 a minute
As I mentioned previously my plenum gasket had been replaced previously. The one I removed had a "plastic" feel to it. It wasn't a paper gasket.
Old Jan 24, 2012 | 11:12 AM
  #103
Originally Posted by Crackshot
So is it safe to say that using the steel plate is fine as long as you use a quality gasket?
and shorter bolts.
Old Jan 24, 2012 | 11:13 AM
  #104
Crackshot's Avatar
Crackshot
Old Jan 24, 2012 | 01:34 PM
  #105
PapaG's Avatar
PapaG
I've been reading up on the plenum repair threads and am planning on doing mine sometime very soon. I should have the parts soon (buying some stuff from a member here) and I was wondering how many of you have used the Dorman gasket set? I have heard some iffy stuff about the Dorman parts but thats what I will be getting...I just don't want to put the work into this project and use inferior gaskets and have to redo it all down the road. So any personal experience with this gasket set? Good or bad...? I saw an earlier post talking about the coolant hose busting shortly after installation.
Another question also. If using a 1/4 in. alum plenum belly plate then is it ok that the bolts with the Dorman kit are same length as stock? I am assuming from all the threads I have read that if using stock plate then bolts are too long but if using thicker plate then stock bolt length would be ok...?
Yeah I know it's some noob questions that have probably been answered before so please excuse my ....noobishness
Old Jan 24, 2012 | 01:52 PM
  #106
woodtrucker's Avatar
woodtrucker
I used Fel-pro. Most on here have used fel-pro.
Here is my cost list. Just swapped mine over the weekend and so far (100 miles) it has been a success!
Old Jan 24, 2012 | 06:36 PM
  #107
Shaggy433's Avatar
Shaggy433
I was wondering the exact same thing about the bolts.. I just bought the plate off of ebay and it came with bolts. Those are the ones I think I'm going to use. I also bought the Dorman kit from orielly's (wish I would have saw that Rock Auto had that kit for damn near half the price!) Going to be doing the swap this weekend.
I went to the junkyard yesterday to remove the intake off of a durango just for practice so that I know what to expect when I do mine and if I break something its not as bad as if it was on mine BUT it was pretty easy to do didn't run into any problems and it took less than 1.5 hours to get it off!
Old Jan 24, 2012 | 06:51 PM
  #108
Augiedoggy's Avatar
Augiedoggy
the aluminum plates are thicker so stock bolt length isnt an issue...
Old Jan 25, 2012 | 06:27 PM
  #109
peshewa's Avatar
peshewa
If you make this also for the 3.9 V6 them tell me & I will buy one!
