DIY Homemade Plenum Plate
Old Jan 5, 2011 | 02:31 PM
jpsycoboy5's Avatar
jpsycoboy5
Default DIY Homemade Plenum Plate
So i don't want to spend the money for a hughes kit and i've called around and can get an 18x10 piece of 1/4 plate aluminum for $24 ill post up pics of each step and what not and hopefully try to save y'all some money i have all of the tools to make them so if you dont have the tools i'd get ya one for 50 plus shipping
Old Jan 5, 2011 | 02:39 PM
DukesOfHazzard's Avatar
DukesOfHazzard
Hope this turns out better than Purpls attempt at DIY good luck and looking forward to it.
Old Jan 5, 2011 | 02:56 PM
jpsycoboy5's Avatar
jpsycoboy5
I'm confused about purpl whole thing did he just not do it or did it and it didn't work or started and never finished?
Old Jan 5, 2011 | 02:58 PM
DukesOfHazzard
your guess is as good as mine
Old Jan 5, 2011 | 03:30 PM
merc225hp's Avatar
merc225hp
I am thinking it was a liablity issue, and smart on his behalf for not doing it.
Old Jan 5, 2011 | 03:32 PM
jpsycoboy5's Avatar
jpsycoboy5
Well I hope it wasnt because it didn't work
Old Jan 5, 2011 | 03:37 PM
merc225hp's Avatar
merc225hp
There are a few people that have made there own plates on here, just remenber if you sell a product to someone and it fails becouse it was not designed right they will be coming after you for the cost of the repairs.
Old Jan 5, 2011 | 03:40 PM
95RAM360's Avatar
95RAM360
OFF TOPIC
hey you have a 95 Lesabre....im trying to figure out how to remove starter....and we had a problem...car would run great, then the starting got slow....turned it off, and it finally went to no Crank at all. All guages work...heat blows full, so i eliminated battery, and alt. since radio and everything still works. There is no click from starter selenoid, and there is power to the starter. The car just wont crank at all....have you had this problem? Its my buddies car and its the same thing as yours.
Old Jan 5, 2011 | 05:38 PM
jpsycoboy5's Avatar
jpsycoboy5
Originally Posted by 95RAM360
OFF TOPIC
I would check the resistance on the battery cables the postice battery cable on mine had high resistance everything would work but when I went to crank it nothing happened
Old Jan 5, 2011 | 06:14 PM
jpsycoboy5's Avatar
jpsycoboy5
That is an excellent point is there anyway to disolve my liability just to help other members?
