Help with trouble codes
Old Jan 5, 2011 | 05:40 PM
Reggie220's Avatar
Reggie220
Default Help with trouble codes
New to this forum as I just bought a 1999 Dodge Ram 1500 quad cab 4x4 with 5.9L motor. The CEL is on, so I got a code reader for cheap on Ebay. I got the codes, but not really sure what to do next. Here are the codes I got and maybe someone here could decifer them for me?
P0420 1/1 Catalytic Conv Eff
P0720 Low Output SPEED Sens RPM, Above 15 MPH
In order to pass inspection the light needs to be off, so I can't just ignore it. I should also add that the truck has a flowmaster exhaust that is loud as hell!
Old Jan 5, 2011 | 05:47 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Start by replacing the pre cat o2 sensor and the Output speed sensor which should be located on the driver side of the tranny towards the transfer case.
Old Jan 5, 2011 | 05:58 PM
Reggie220's Avatar
Reggie220
Thank you so much for the quick reply, so I should get these?
http://www.napaonline.com/Search/Det...+50022+2022009
Not sure which sensor:
or
Thank you, Reggie
Old Jan 5, 2011 | 06:02 PM
zman17's Avatar
zman17
Those links don't work at NAPA when some else views them.
Old Jan 5, 2011 | 06:09 PM
Reggie220's Avatar
Reggie220
Old Jan 5, 2011 | 06:22 PM
Nope. Don't think you can direct link to the parts.
Old Jan 5, 2011 | 06:35 PM
Reggie220's Avatar
Reggie220
ok, emailed links to myself using their email this item feature, so they should work this time:?
Speed sensors:
http://www.napaonline.com/Search/Det...100_0248567769
or
http://www.napaonline.com/Search/Det...065_0252665128
o2 sensor:
http://www.napaonline.com/Search/Det...151_0295696170
please work...
Old Jan 5, 2011 | 06:36 PM
LOLOL
Nope. Still doesn't work.
Old Jan 5, 2011 | 06:51 PM
Reggie220's Avatar
Reggie220
maybe this helps?
Old Jan 6, 2011 | 10:15 AM
Reggie220's Avatar
Reggie220
OK, I ordered these, they the right ones maybe?
http://shop.advanceautoparts.com/web..._1444139463___
http://shop.advanceautoparts.com/web...___#fragment-1
