Transfer case
Old Jan 8, 2011 | 09:04 AM
ramit99's Avatar
ramit99
Default Transfer case
I have a 99 2500. Never had a problem with 4x4. Always change the fluid every year. Lately when in 4x4 the trensfer case makes a bit of a rattling sound but eventually goes away. I think its coming form the case. Just changed the fluid again yesterday. No metal in it. 4x4 still works. Any ideas? Thanks
Old Jan 8, 2011 | 09:23 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Look into one of these http://www.drivetrain.com/parts_cata...ase_saver.html and check your front driveshaft.
Old Jan 8, 2011 | 09:36 AM
ramit99's Avatar
ramit99
Driveshaft seems okay. I did both u joints a year or so ago. It makes the noise in 4L as well.
Old Jan 8, 2011 | 12:23 PM
matty675's Avatar
matty675
sure it goes away? may be a sloppy chain, if so keep it out of 4wd. chain doesnt move in 2wd
http://www.youtube.com/watch?v=svZ8gwCpo9k
Old Jan 8, 2011 | 12:25 PM
UnregisteredUser's Avatar
UnregisteredUser
If it is a broken snap ring your transfer case is in grave danger. Check that out right away, and replace it with the transfer case saver if it's broken. Or even if it's not.
Another possible cause is a broken mount, or a sloppy transfer case chain. If the chain is slapping the case it's just a matter of time before very bad things happen.
Old Jan 8, 2011 | 01:04 PM
ramit99's Avatar
ramit99
What would cause the chain to go slack all of a sudden its been working fine. Is there a tensioner or adjuster on it?
Old Jan 8, 2011 | 02:46 PM
matty675's Avatar
matty675
no tensioner, it should be a gradual process, verify the noise first.
Old Jan 15, 2011 | 12:41 AM
ramit99's Avatar
ramit99
Well what i thought was my transfer case turned out to be the front ujoint on the output shaft to front diff. Replaced it 2 years ago. One cup ceased solid.27 bucks. Good as new.
Old Jan 15, 2011 | 07:37 PM
ramit99's Avatar
ramit99
Wrong again! The noise is back. Sounds like the u joint at the transfer case. One of the two. Is there a bearing on the output shaft as well. It was squeakin a bit too when i turned it by hand. Is that a big job to replace the bearing and seal? Also to get the output shaft off do you undo the 4 bolts holding the yoke? Thanks
Old Jan 15, 2011 | 07:51 PM
Fix the ujoints first. See if that doesn't take care of it.
