lucas products
Old Jan 8, 2011 | 04:30 PM
CPTAFW163's Avatar
CPTAFW163
Originally Posted by PurplDodge
I used Lucas once in my transmission. It was before I had my trans re-built the first time. I was trying to make it last as long as it could (In reality I was killing it faster by using Lucas). When I had it re-built the guy who re-built it said the fluid looked like milk and the insides were a foamy mess. Never use it. All the oil treatment is 80wt with some soap. It causes the oil to dilute, yet thicken and loose its anti foam properties causing a motor oil milkshake. I imagine that the trans treatment is probably the same.
USE ATF+4 and Only ATF+4.
1. It is more than 80WT. More like 300WT.
2. No Soap
3. It has anti foam in it.
4. No oil has anti foam built in. Hence why you add limited slip additive to Diff oil (All limited slip additive is...is anti foam).
I know what you are referring to about the milkshake, that guy who did that test. But there was only one flaw in that test: It is not done at engine or differential operating temps.
I once drained my engine oil (with 1 QT lucas) right after driving at operating temp for a while. And although I singed my fingers because of the oil being hot, it was not a milkshake. It looked like normal.
I can only go by my firsthand experience on this one. Lucas used in my engine:
1. Never milkshaked
2. My engine is squeaky clean: Probably more because of the previous owner using Mobil I Syn at every oil change and him not adding any engine restore or flush type additives. But after 2 years of using lucas every 3000 miles, it is clean.
CPTAFW163's Avatar
CPTAFW163
Let me re-iterate:
NEVER USE ANYTHING IN THE TRANNY EXCEPT ATF+4!!!!
Old Jan 8, 2011 | 04:44 PM
chastain90's Avatar
chastain90
what about the z max stuff they have oil additive and fuel additive are they any good?
Old Jan 8, 2011 | 04:48 PM
CPTAFW163's Avatar
CPTAFW163
how many miles do you have on your truck? Because, anything under 80K, I would just keep away from engine oil additives. Just use good synthetic 10W40 for your 2001.
Old Jan 8, 2011 | 05:30 PM
matty675's Avatar
matty675
my problem with the lucas is the fact that it raises viscosity to a weight the engine was not intended to use
Old Jan 8, 2011 | 05:41 PM
CPTAFW163's Avatar
CPTAFW163
That is why you use it on higher mileage engines, or older engines. Because it is no longer a "tight" engine. my 1996 5.2 required 5W20 (written on the oil fill cap). After 150K you cannot tell me that 5W20 is good enough for a truck.
Old Jan 8, 2011 | 06:24 PM
PurplDodge's Avatar
PurplDodge
I dont believe 5W-20 existed in 1996.
Here is my 2 cents on additives: DONT USE THEM! Zmax is snake oil. Lucas is 300Wt oil. Unless you have underlying problems....Wait, if you have underlying problems, fix them, not cover them up.
Old Jan 8, 2011 | 07:04 PM
Buellstunter's Avatar
Buellstunter
I cant speak for the dodge engines since I have only owned them for a short time. But my Oldsmobile bravada that I just sold had 215,432 miles on it when I sold it. I ran lucas oil and trans additive in it. It carried about 40lbs of oil pressure at idle and 60lbs driving. I bought the truck with 90,XXX miles on it. and used lucas oil stabilizer in it from day 1 of purchase. I changed the oil every 3500 miles. when I needed to change my intake gaskets at 200K I also decided to do the valve covers as well. The valvetrain was incredibly clean looking for an engine with 200K+ miles. So whether or not it works is an opinion. Mine is it don't seem to harm it. I put a litre of lucas trans. additive in my recently purchased ram 1500 5.9L with 100,000 on it. So if it goes out I will let you know. Of course it could be from the 38" swampers and What I believe to be stock gearing too. lol
Old Jan 8, 2011 | 07:08 PM
PurplDodge's Avatar
PurplDodge
I see your point, but a 4.3 will go almost forever on little or no maintnace.
Old Jan 8, 2011 | 07:12 PM
matty675's Avatar
matty675
ITS NOT OPPINION, but if you would like to add it go right ahead...
as far as it increasing viscosity to raise oil pressure in worn engines, thats very true and i guess it cant hurt in that situation; however it is just masking the fact that clearances are out of OEM spec
