99 dodge ram no lowbeam
Old Jan 8, 2011 | 05:45 PM
jbrydes's Avatar
jbrydes
Default 99 dodge ram no lowbeam
I got a 99 ram 5.9 with no lowbeam,all other lights work,when i switch to highbeam the the the bulb that runs the running lights/lowbeams gets brighter,all the fuses and relays have been checked by three different people,i just changed the headlight switch,no go,just wondering if there is any hidden inline fuses or relays,any help would be awsome.
Old Jan 8, 2011 | 05:53 PM
2 or four headlight system?
Do you have tilt wheel? If so, check the wiring at the multifunction switch in the steering column.
Old Jan 8, 2011 | 06:42 PM
Randy_W's Avatar
Randy_W
My old '99 3/4 ton had no low beams unless I tilted the column all way up, there was a wire loose from the connecter in the steering column, plugged it in solid and all was well!
Old Jan 8, 2011 | 09:02 PM
jbrydes's Avatar
jbrydes
thanks i had the column some what apart nothing looked out of place i will pull it apart again and check for loose wires.
